Usg vpn site to site UP but not working
Following some guides found on Internet is probably not a very good starting point: why not simply start with official ZyXEL KB Articles as foundation for your configurations? it's the path I personally prefer.
As example:- ZyXEL IPSec VPN Site to Site (Static IP Public addresses) KB Article
- ZyXEL VTI VPN Site to Site (Static IP Public addresses) KB Article <-- if you have both USG with 4.20 or newer you can use VTI instead of more common IPSec approach (useful if you are planning in near/far future to perform VPN tunnel balancing over two WAN interfaces on each side).
@parnassus, Thanks for your sharing.
Hello Roma123,
I want to confirm that is your topology like
USG110--(VPN connection)---internet---(VPN connection)--USG210?
You can follow the configuration which parnassus shared, and here is the similar example of VPN from FAQ as your reference.
https://businessforum.zyxel.com/discussion/551/an-example-of-site-to-site-vpn#latest
Charlie0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
