ZYXEL WAH7706 and leopard iMac (g4 ppc)
jcreb
bonjour
J’ai installer ZYXEL WAH7706 sur mon iMac sierra et tout est parfait mais quand j’ai voulu me connecter sur un autre iMac sur léopard ( g4 ppc )
le réseau zyxel 392c n’apparait pas.Est il incompatible avec les mac PPC
Merci
Hello
I install ZYXEL WAH7706 on my Sierra iMac and everything is perfect but when I wanted to connect to another leopard iMac (g4 ppc)
the zyxel network 392c does not appear.Is it incompatible with mac PPC
Thank you
#LTE_Aug
Hi jcreb,
You mentioned “the zyxel network 392c does not appear.Is it incompatible with mac PPC”, does it mean you cannot find both 2.4G and 5G SSID on your leopard iMac?
Can you please help to share firmware version of your WAH7706 and correct OS version of leopard iMac?
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
