Zycel AMG1302-T10A router
I have a Zycel AMG1302-T10A router, which I obtained in 2013. Recently, I decided to change the passwords. If I type 192.168.1.1. into my address bar, all I get is a list of sites, It does not go direct to the interface leading to the configuration. I checked on the Zycel site and my router model number is not listed among those available. Neither is it found, if I type the model number in manually. I am guessing that this is now a model which is obsolete and unsupported and that I need a new router. Would this be correct, please?
#CPE_Aug
Hi JWS,
This is phase out model in 2016 so that’s why you cannot get this information from our website. I suggest you can clean browser cookies or factory reset device to check if it recovers or not.
Hi JWS,
Many thanks for that. Reset worked like magic. JWS.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
