USG problem with port lock with NAT RDP
PauloJrMcz
Posts: 3 Freshman Member
Good morning, I would like to understand the reason for the several drops I'm having when linking the access from the outside to the inside using the NAT for an internal server through port 3389, that is the NAT was done right, but when trying to access from outside the network it rejects according to prints. What you need to do the most.
#Biz_Security_Aug
#Biz_Security_Aug
Hi
Had you configured the security polity to allow certain traffic going down? I found there's a FAQ in the Zywall/USG forum link. Here it is
https://businessforum.zyxel.com/discussion/1448/how-to-setup-port-forwarding-to-my-internal-rdp-pc
Hello, I did not understand when you said decrease traffic, but this material that you indicated to me does not have much difference in what I did, what I'm trying to say is that even constructing the NAT rule, including your suggestion in the FAQ, still access from outside the network or only accepting the NAT within my network, follows image.
Interesting is that when I use the redirect in the default port 3389 and use the RDP service it works perfectly which is not working when I define an external port itself.
- 347 Beta Program
- 2.1K Nebula
- 114 Nebula Ideas
- 77 Nebula Status and Incidents
- 5K Security
- 44 USG FLEX H Series
- 246 Security Ideas
- 1.2K Switch
- 65 Switch Ideas
- 901 WirelessLAN
- 33 WLAN Ideas
- 5.8K Consumer Product
- 204 Service & License
- 326 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.8K FAQ
- 831 Nebula FAQ
- 401 Security FAQ
- 219 Switch FAQ
- 190 WirelessLAN FAQ
- 45 Consumer Product FAQ
- 136 Service & License FAQ
- 71 About Community
- 61 Security Highlight
