VMG8924-B10A LAN Ports Intermittent Failure
Hi all good so far, yes when it went you could no longer ping the router from wired connection, Wifi was fine though.Thanks for the help.0
I have this same issue and I have noticed that when the Bytes In or Bytes Out hits the maximum integer value, the port fails. Might be logging related, don't really know - all I know is that it's pretty annoying at times.
If it is a bug in logging, changing the value type from integer to long should fix it (on the developer side).
Hi Bonsaipanda,
That’s a great discovery in VMG8924.
Just want to know if we wait for a while, will that value turn back to 0?
- 211 Nebula Ideas
- 545 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 465 News and Release
