vmg4825-b10a Network drive not working
fox
I have a USB drive connected to the router & set the shares to enabled & selected the directories to be public but nothing shows up on my pc's.
#CPE_Sep
#CPE_Sep
Hi fox,
May I know your VMG firmware version?
And which OS is used by your computer? Is it windos10?
If the win10 system is used, you should enable the SMB1.0 first.
Below is a FQA for the SMB1.0 setting in win10, FYR
https://homeforum.zyxel.com/discussion/850/how-to-find-usb-share-in-windows10#latest
V5.11(ABFT.1)C0Windows 70
Hi fox
"Media Server" would show an icon on your PC's "Network".
If you use "File Sharing" you need to input "\\192.168.1.1" in Windows Search.
Then you can see the shared folders.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
