how to enable http access on ZyXEL VMG8924-B10A using PuTTY
matthew1967
A while ago i accidentally disabled HTTP access on my router at home(I thought i was disabling it on a different router but it redirected me). A year has past and i forgot about it but now i need to port forward something. i have tried port forwarding on putty but it doesn't seem to work. please can somebody guide me on how to do this! thanks.
#CPE_Sep
#CPE_Sep
Hi matthew1967,
You want to login web GUI but you have disabled the LAN/WLAN HTTP service before?
Could you try the HTTPs connection? Have you also disable the LAN side HTTPs service?
If the answer is yes, I think you must do the factory reset to solve the issue.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
