ZyXEL VMG1312-B30A and Digitalisierungsbox Basic
Do ZyXEL VMG1312-B30A support supervectoringe? perhaps after a firmware update?
Second Question about Digitalisierungsbox Basic
I replaced the VMG1312-B30A with Digitalisierungsbox Basic ... the replacement was 1 to 1
I would use the Digitalisierungsbox Basic as a pure modem, so i switched in webmenu to modem mode. The DSL Synchronisation looks good, but i don't PPPOE packets back? What else I have to do, to bring this modem online?
#CPE_Sep
Hi thomas_will,
You can check VMG1312-B30A specification in Zyxel website, there is a link for you:
VMG1312-B30A can be a pure modem too, just insert the WAN side cable.
If you want to change it to the PPP connection, it can be modified it in the web GUI also.
Hi thomas_will,
Hi thomas_will,
Hi thomas_will,
Hi thomas_will,
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
