Port forwarding on Multy x
123_RR
I must forward some ports to my internal server. port 80, 443, 8080 and so on. This is the most ports we do port forwarding on, and that are not possible because "The port was reserved for system use" if I cant forward these ports, is the routher is useless for me, is it possible to come around this, or must I buy another router brand for this?
#MultyX_Oct_2018
#MultyX_Oct_2018
Multy X has reserved some specific port for system use.
You can use others port number for external port to map you internal port.For example:
8088 <-> 80
4343 <-> 443
8989 <-> 80800
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
