GS1200-5 changed hardware mac-address in the LAN by itself
Hi AndyE,
Thanks for the information. I will test it.
And is GS1200-5 only connect two IP Phones?
Do you encountered the problem after GS1200-5 MAC Address has changed?0 -
Hi Teemo,
the GS1200-5 and the two ip-phones are allways on and connected. There is a third device (a samsung tv receiver) which is sometime active.
After the MAC Address has changed there are no further problems identified.
br
andy0 -
Hi AndyE,
thanks for coming back to the main topic.
The two GS1200-5 changed the MAC as follows:
“B8:EC:A3:96:BF:DE“ original printed on the bottom and seen on the network.
Later „02:01:06:00:F7:FE“, even if there was made a firmware update and reset.
“B8:EC:A3:96:BF:EE“ original printed on the bottom and seen on the network.
One of the GS1200-8 has printed on the bottom the „02:01:06:00:F7:FE“ and works fine.
I disconnected both -5 and connected one new -8. This networks works without any problem and change of MAC!
regards Uwe
Hi Uwe,
thanks for your reply.
This is exactly what I have expected. All device have the same MAC after it have changed. Your devices have the same like mine.
It seems to be a bug.
br andy
@Steven: Thanks for investigation the problem.One correction to my reports:"One of the GS1200-8 has printed on the bottom the „02:01:06:00:F7:FE“ and > works fine."Sorry, this was my mistake. GS1200-8 changed too !!!The original Information on the bottom is as follows:B8ECA396C975, Serial Number: S174351010338purchased in Germany, amazon.de, June 2018regardsUwe0
We have contacted you via private message. Please kindly check your message box.
I have this problem tooGS1200-5V1.00(ABKM.0)C0Sticker printered:S184329002860B8ECA3FA3F12GS1200-8V1.0(ABME.0)C0Sticker printered:S184329004614B8ECA3FA478BMAC two device
02:01:06:01:F7:FDRouter ->GS1200-8 -> GS1200-5DHCP client so it does not work and always Loop detect and breaking up connections two switch0 -
@Gme24,
In order to provide you with a better assistance, we have contacted you via private message.
Please kindly check your message box.0 -
Faced the same problem. 2 devices have a MAC 02:01:06:00:F7:FE What to do? I purchased several devices that will work on the same network. If the rest will work the same, this is a nightmare. Help me please.
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 360 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
