Finding same household electrical circuit?
JBrondos
I have tried plugging in my PLA5456 units into various outlets, but I cannot get the home light to light up.
#PLA_Nov_2018
#PLA_Nov_2018
Do you try to reset them?
After reset, they will have the same group key, and you are able to see the Homeplug LED light and it means the 2 PLAs are connected.
Moreover, you can press encrypt button within 0.5~2.5 sec, then the 2 PLAs will pair to each other, and you are able to use them in your network.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
