VMG8823-BX0B ne reconnait plus le login admin après changement password
smonifu
I change the password as asked at the first connection and I could'nt connect again to the router which does'nt reconize the login "admin" ?!
What can I do ? Thank's for help me
#CPE_Nov_2018
#CPE_Nov_2018
Hi smonifu,
You just cannot login as admin after changed password? Or you cannot access to 192.168.1.1? Or internet access is blocked?
You can try to clean browser cookies or reset device back to default if it’s need. If it still happens after reset to default, you may provide steps/passwords to me via PM. Then I can try if I can find same situation.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
