Zyxel Multy X connection to the Modem
Bence
The Zyxel Multy X will it work, if the both router connect with UTP cable to the Modem? This is not problem? Or I just need to connect 1 router?
#MultyX_Nov_2018
#MultyX_Nov_2018
I mean connect the 2 router to the Modem 2 LAN Port.
-> 2 routers are 2 Multy X units? It's not very clear about your description.
Can you share what kind topology you want?
And do you want that two Multy X nodes are connected via Ethernet cable directly, not use wireless dedicated backhaul?1
What do you mena "if the both router connect with UTP cable to the Modem"?
Can you explain more detail?
Multy X can connect the Modem or the Router.
.Internet---Modem<LAN Port>---<WAN Port>1st Multy X node)))<WLAN>(((2nd Multy node
.Internet---Modem<LAN Port>---<WAN Port>Router<LAN Port>---<WAN Port>1st Multy X node)))<WLAN>(((2nd Multy node
I read a lot and saw lot of videos about how to connect 2 or 3 router. They turn off the DHCP server and change the IP Adress. If I know well, the LAN Ports on the modem are the natural connections and WAN port is the internet connection and WLAN is the same as LAN on WIFI.
I mean connect the 2 router to the Modem 2 LAN Port. And after that I connect to the 2 WAN port on the routers. Will it work?
I'm afraid about the second router will be slow if it only connect on WLAN.0 -
And do you want that two Multy X nodes are connected via Ethernet cable directly, not use wireless dedicated backhaul?1 -
Yes, i don't want to use wireless dedicated backhaul.0 -
Multy X seems not ready to support Ethernet backhaul.
Please refer to:
https://homeforum.zyxel.com/discussion/comment/3583#Comment_3583
BTW, Multy X has wireless dedicated backhaul.
Just reminder, Multy X is the "WiFi" System.
Do you mean:
If yes, you need to create two Multy X WiFi System, they are both as root node.
- 234 Nebula Ideas
- 6.7K Security
- 722 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
