How to use MuninLite
silax
Who knows how to use MuninLite? I recently installed it through Repo: Mijself.
#Others_Dec_2018
#Others_Dec_2018
Best Answers
You need a Munin master and then your NAS running MuninLite can act as node. When I remember well you only need to enter the IP or hostname of the NAS in the master, and then it gathers statistics about disk and network usage.
Yes. There are some caveats, but those are covered in the webpage which the Entware-ng zypkg provides.BTW, I wouldn't be surprised if Munin can also run on FFP.0
thanks for your response
Do you know if is possible to install Munin master on my Zyxel 325v2 ? 0 -
I wouldn't know why not. There is enough CPU and memory. I think all needed dependencies can be provided by Entware-ng.But it can keep your disks from spinning down, due to the logs Munin will generate.0
Great news ! Currently i use ffp 0.7 zypkg006 from your repository
.Could i use both repository? ffp 0.7 and entware-ng ? 0 -
- 588 USG FLEX H Series
- 477 News and Release
