How to use MuninLite
silax
silax Posts: 8 image  Freshman Member
Fourth Anniversary
edited December 2018 in Smart Home Product
Who knows how to use MuninLite? I recently installed it through Repo: Mijself.
#Others_Dec_2018
Best Answers
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    You need a Munin master and then your NAS running MuninLite can act as node. When I remember well you only need to enter the IP or hostname of the NAS in the master, and then it gathers statistics about disk and network usage.
  • Mijzelf
    Yes. There are some caveats, but those are covered in the webpage which the Entware-ng zypkg provides.
    BTW, I wouldn't be surprised if Munin can also run on FFP.
  • Mijzelf
  • silax
    Fourth Anniversary
    thanks for your response :smile: Do you know if is possible to install Munin master on my Zyxel 325v2 ?
  • Mijzelf
    I wouldn't know why not. There is enough CPU and memory. I think all needed dependencies can be provided by Entware-ng.
    But it can keep your disks from spinning down, due to the logs Munin will generate.
  • silax
    Fourth Anniversary
    Great news ! Currently i use ffp 0.7 zypkg006 from your repository  :) .Could i use both repository? ffp 0.7 and entware-ng ?
  • Mijzelf
