Powerline adaptors of Compatibilty
AnndieHomes
Hello everyone,,,
I have a pair of PLA5206 . I can't seem to be able to add other (older PLA5206 v2) adaptors to the same network. Any help gratefully received....
#PLA_Dec_2018
#PLA_Dec_2018
You can try to reset both, default they are using the same group, then it can communicate to each other.
If you would not like to use default group, press encrypt button 0.5 ~2.5 seconds, they should be able to sync and light the homeplug LED.
Another way that you can use utility to configure the group to make they work.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
