Hi rafaelsolano,
Not sure which PC you use for login, provide a way for checking the VMG gateway here:
1. Open your PC “Terminal”
2. Type: ipconfig.
3. Find “Default Gateway”, and use this IP address for login.
Having trouble with credentials in VMG1312-B10D
rafaelsolano
I have trouble logging into the WiFi router whenever I put in the default router IP address. It keeps me redirecting to a different IP address and the default username and passwords don't work.
#CPE_Jan_2019
#CPE_Jan_2019
Have you tried to log in with a different browser? Sometimes a browser may cause a problem due to the cache memory. Clearing it will resolve your issue.1
Hi, thanks for reaching out. Yes, I have tried to login with 192.168.10.1 routerlogin website on Firefox as well as the Opera Browser but no success.
What else do you suggest?0 -
If you have multiple routers (or router with a separate modem), it sometimes will change the default IP to another one. Maybe instead of using the phone's browser to access the router's setting, try to download the router's App alternatively (most major router brand has its app you can use). If not, you could try to reset the router maybe and reconfigure it.
Hi AAAAL,
I have the NBG-418N and I am using a MacBook Air to configure my WiFi router.0
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 353 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
