WAH7706 wifi range
Exelyfe
I know that the range can vary depending on the conditions, but in optimal conditions (large open room, no blockades between the router and the unit), what will the expected wifi range then be, on the WAH7706?
Thank you in advance.
#LTE_Jan_2019
#LTE_Jan_2019
Hi Exelyfe,
The range is about 150m, it must be in a clear environment (no other AP signal, open space, no blockades etc). But I would like to let you know, the speed will be affected by signal strength, test clients etc. So speed is depending on conditions also.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
