Your firmware version is 1.00(AAKL.28)C0, right?
Have you check below FAQ and still cannot find the USB filer?
https://homeforum.zyxel.com/discussion/850/how-to-find-usb-share-in-windows10#latest
Cant access USB drive
1bit
I have just bought a Zyxell VMG8924-B10A and its on the latest firmware, I have a USB stick on it and enabled MEDIA SERVER and FILE SHARING, when I click on Media Server in Windows 10 Network List it opens a web page saying -
"This 192.168.1.1 page can’t be found
No webpage was found for the web address: http://192.168.1.1:2468/webs/html_root/index.html"
can anyone help?
thanks in advance
#CPE_Jan_2019
can anyone help?
thanks in advance
#CPE_Jan_2019
I am able to access the admin page only when connected directly to the router with an ethernet connection.Are you connected through ethernet?0
You can refer to this post to check if it can be resolved or not.
Yes, I did.0 -
I got this working, you have to enter the URL into the address bar of File Explorer in windows, in the NETWORK folder it will show you the router, simply type the share into the address bar and you get access0
- 588 USG FLEX H Series
- 476 News and Release
