VMG8823 web gui access
NeAl
VMG8823-B50B
firmware version V5.13(ABEJ.5)C0
I'm using mutiple wi-fi networks on the same modem (via the Guest/More
AP function).
I've noticed that, if I set "Max. Upstream Bandwidth" and "Max.
Downstream Bandwidth" on the main wi-fi, I cannot login anymore on the
web GUI while connected to the main wi-fi.
I can still login if I connect to another wi-fi.
If I remove both "Max. Upstream Bandwidth" and "Max. Downstream
Bandwidth" limits on the main wi-fi, I am able to login again on the web
GUI.
Bug or "undocumented feature"?
#CPE_Jan_2019
AP function).
GUI.
#CPE_Jan_2019
Hi NeAl,
What’s your "Max. Upstream Bandwidth" & "Max. Downstream Bandwidth" setting?
Can you share the value?
Hi AAAAL, thank you.
Limits for Wireless / General are:
Max. Upstream Bandwidth: 999 Kbps
Max. Downstream Bandwidth: 8888 Kbps
I'm using 2.4GHz network only.
If it's relevant, modem syncs at 10488 Down / 1145 Up (Kbps).0 -
Hi NeAl,
We can find similar situation as yours so we will have internal discussion. Will let you know if have further update.
Any news on this issue?
Is there a planned firmware update?0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 307 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
