ZyXel WAP3205 v3 - Access Point not allowing Samba filenames across
BigBadMadBill
I have two QNAP servers, a Zyxel GS1920-24-1 switch and a Billion WAN/WI-Fi hub. The various items of infrastructure are wired connections, Wi-Fi is only used to connect endpoint things like laptops, tablets & phones to the network.
I had trouble connecting in one room and so purchased a WAP3205 v3 wirless access point and connected it up and all seemed tickety-boo at first. But I seem to have a problem accessing (SAMBA) shared drives on my NASs on laptops connected via the WAP. The problem being that Windows explorer just cannot see these shared drives at all. If I disconnect from the Zyxel WAP and connect into the Billion Wi-Fi hub I can now access these drives.
Anyone got any ideas?
#Repeater_Jan_2019
#Repeater_Jan_2019
What is your firwmware version?
latest version:v2.00(ABDM.4)C0, WAP3205 v3 connect to router directly, my samba server is connecting to router, but I was set the static IP as the same sunbet as router, then I can access it over wireless and ethernet.
My version is V2.00(ABDM.2)C0
I don't quite understand what you mean when you say "I was set the static IP as the same sunbet as router" but I think you mean that it has the same subnet address as router? If yes then so have I.
I think it may be that the reception in the room the laptop was in at the time is marginal. So I need to run a few tests.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
