Hi phantomjinx,
May I know had you enable the sys log on GUI: Maintenance -> log setting -> Syslog Logging -> enable
Then you can find the logs display on System Monitor -> Log
Zyxel VMG1312-B10D log error displayed
phantomjinx
Have just bought the Zyxel VMG1312-810D (firmware: V5.13(AAXA.5)C0).
When I click on System Monitor > Log an alert dialog is displayed with the message:
Looking at the filesystem using ssh ..
phantomjinx
#CPE_December
"Fail do action"Clicking this away, no logs are displayed.
/var/log srw-rw-rw- 1 root 0 0 Dec 17 06:07 log -rwxr--r-- 1 root 0 8387 Dec 18 11:46 security.log -rwxr--r-- 1 root 0 18520 Dec 18 13:09 syslog.log -rwxr--r-- 1 root 0 34257 Dec 18 12:25 syslog.log.1So defintely logs there. Also, configured remote syslog (selected Remote and File) and see logs now being sent across to my server. Looking at the javascript source code, the dialog display occurs in /web/pages/system_monitor/log.js at L116:
112 fnFailure: function(trans, response, args){ 113 if(response.status == 504) 114 location.href = "/"; //redirect to 192.168.1.1 115 else 116 openAlertPanel("error", "Error", "Fail do Log action"); 117 closeLoadingPanel(); 118 q.end(); 119 } 120 }; 121 if(typeof cat != "undefined" && cat != 0) o.url += "&category="+cat; 122 httpReqSendAndRecv(o); where: * o.url = "/cgi-bin/Log?action=GET_LOG&oid=RDM_OID_LOG_CLASSIFY&sessionkey=833526475" * response.status = 0 * trans = 39Again, looking on the filesystem:
- Cannot find any *.cgi files;
- Cannot find a script file of any kind named Log;
- Cannot find a cgi-bin directory which is normally used for executing cgi scripts.
phantomjinx
#CPE_December
Are you using an adblock?
Could you try disabling/whitelisting the adblock for the modem ip address?0 -
Excellent topic. Thank you.0
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 368 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
