Unable to access Zyxel configuration page
Clowningman
The default local IP address of my Zyxel switch is apparently 192.168.1.3. However I can not find it at that address. My computers are in the 192.168.10.xxx -range. How can I access the switch config page?
#Home_Switch_Jan_2019
Please refer to the Quick Start Guide:
https://www.zyxel.com/support/download_landing/product/gs1200_5_gs1200_8_18.shtml?c=gb&l=en&pid=20180126103420&tab=Quick_Start_Guide&pname=GS1200-5/GS1200-8
You need to configure your computer IP as 192.168.1.*, when your computer IP and switch has the same subnet, then you can access it.
After login switch, you can change its IP as 192.168.10.* and remember change back your computer IP to "Obtain an IP address automatically".
2
2
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
