You want to set up your NAS under the VMG8825-B50B LAN side?
And your NAS device has a Ethernet connection to VMG8825, right?
I don’t know the NAS behavior here, you may need to check with the NAS provider.
NAS CONNECTED TO VM8825 B50B HOW TO STEP BY STEP
wallacepc67
Hi , I'm typing from Italy . I read a Q&A based on similar problem in other discussion. Now, I have this HUB Router with a NAS connected by Ethernet inside my network . I'm a private client. It seems that , here in italy, nobody knows the configuration for a correct connection of the device mentioned (NAS) from outside ----> inside my network . Connection VDSL . Thanks in advance for your kindly support
#CPE_Feb_2019
Hi wallacepc67,
Thanks , first of all for your feedback. I sent an email to NAS Company (Synology) but it seems that the best play here in Italy is to rebound the question from one side to another (Synology <-> internet provider )and honestly I don't how which are the correct setup for 8825.....0
- 588 USG FLEX H Series
- 476 News and Release
