You can check VMG8825-B50B USB Service on the User Guide Chapter
16, then set up USB connection as well.
There is a link for your reference: https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=M-02847&md=VMG8825-B50B
Zyxel Digital Media Server (VMG8825-B50B-IT01V1F
Cesare
If I click on "Zyxel Digital Media Server" icon (Periferica disponibile in rete), the PC answer:
This page contains the folloving errors :
error on line 1 at columns 15: DOCTYPE improperly terminated
Below is a rendering of the page up to the first error.
The input line after the click : 192.168.1.1.:2468/usr/webs/html_root/index.html/
What can I do to see the USB port of the Zyxel product on my PC ?
Thanks.
#CPE_Feb_2019
To see the drive on the USB port you need to share the folders you want within the router setup page (USB service), then open windows explorer and insert the address \\192.168.1.1\
Hi Cesare,
- 588 USG FLEX H Series
- 477 News and Release
