Where is the release notes for Multy X v2.10(ABKJ.7)C0?
fuigo
fuigo Posts: 3 image  Freshman Member
edited February 2019 in Multy WiFi System
Where is the release notes for Multy X v2.10(ABKJ.7)C0?  I can’t find it anywhere.  Does anyone know what’s new on this version?
#MultyX_Feb_2019
Best Answers
  • MIBSWE
    MIBSWE Posts: 35
    It's usual for Zyxel to release firmware before the release notes. Found a link from the previous release and modified it for this release, but it doesn't work ftp://ftp2.zyxel.com/WSQ50/firmware/V2.10(ABKJ.7)C0.pdf. I guess they will post a link soon, I hope.
  • MIBSWE
    MIBSWE Posts: 35
    It seems that the firmware update was just for the Speedtest issue which I and many others experienced.
    Recently, Ookla (Speedtest) server has changed its protocol from http to https to cause Multy X cannot get server list. We are working to modify the configuration file of Speedtest and will release new firmware to fix this issue soon.
    Update.
    New firmware and new App has released to fix this issue.
  • MIBSWE
    MIBSWE Posts: 35
  • MIBSWE
    MIBSWE Posts: 35
    Update.
  • fuigo
    Thanks! For the response. I thought something was off with Speedtest. It worked perrfectly last night after the update.
    I was was hoping to see Ethernet backhaul to be added.....
  • Stormjai
    Stormjai Posts: 2 image  Freshman Member
    No totification of firmware update so far?  Can I find/update in settings?
  • Dash
    Dash Posts: 65 image  Ally Member
