impossible to open the port on my router 8825 zyxel
mauri
hello there, i m trying to connect my ipcam at my router and to do that i need to open the door 86, I have been tryng many alternatives also with the DMZ but nothing! all the port are always closed. ANy suggestion or something else that i should do after the port forwarding ? thanx for all your support. version firmware :V5.13(ABLZ.0)b10_20180319
#CPE_Feb_2019
#CPE_Feb_2019
Hi mauri,
Could you please try the following:
Network setting / NAT
Add New Rule
Server IP address = ipcam address
Start port = End port = 86 (I would use a different, non-standard port, eg. 8686)
Translation start port = Translation end port = 86
Protocol = TCP, UDP or ALL (in doubt, use ALL)
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
