Adding WPAD(Web-Proxy ) data.
Hi @SYK
Creating a WPAD (code: 252) entry in DHCP option has been on NSG and NCC already.
You can go to Gateway > Configure > Interface addressing to edit LAN interface. In edited window, there is Extended options, and hit Add new button to create DHCP Option for WPAD entry.
Is this option available on the USG devices?0
Hi @SNC
Yes! Of course! You can follow the path below to set up on USG.- Log in USG local giu, and go to Configuration > Network > Interface > Ethernet tag
- Double click USG LAN to edit.
- Select the DHCP as DHCP Server, and click Show Advanced Settings on the top left.
- Click Add in the Extended Options block to add DHCP Option.
- Last, click OK to finish.
hi @ Nebula_IreneWhen I look at that location on USG40 or USG60 Devices under DHCP there is no Advance (Extended Options)
If I click Add by Static DHCP Table I can only add ip addresses. Is there another location I am missing?
You are incorrect even with dhcp server enabled there is no add dhcp option. The screen is identical to the screenshots I posted. We also have the latest firmware installed.0
SNC did you hit "show advanced setting" on the top left?
mine is usg20vpn, Firmware Version:V4.25(ABAR.0) / 2017-04-21 07:54:38
not the lastest but it's there0 -
OMG, you are correct. I forgot to hit the show advanced settings.
Do you know if it's possible to add a url? We have ip phones and would like to add option 66 pointing to a url but did not see a url option in the drop down box.
Is the WDAP available for SBG3600?
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 638 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 54 Wireless Ideas
- 301 Service & License
- 494 News and Release
- 93 Security Advisories
- 109 Security Highlight
