How to set up time-limit of one LAN cables - USG20-VPN
We have bought a new USG-20.
I want to limit the access for one of my children on one of the LAN.
I have the following guide, - but its not enough for me to do the set up, sice I am a beginner in this area..
1. Create two different schedules (one for MON-FRI, 1 for SAT + SUN ) under COnfoiguiration > Object > Schedule
2. Go to Interface > Network > Ethernet select the interface you are using (check under interface > network > Port role which port is assigned to which interface)
3. Scroll down to "Static DHCP Table" and make an entry for the client (e.g. 192.168.1.100 IP, MAC AA:BB:CC:DD:EE:FF)
I recommend to set the IP to 192.168.1.100 and then enter client MAC address
4. Go To Object > Address and add a HOST object with Client IP
5. Then go to Firewall and create firewall rule which looks like this:
Can someone made this guide better , so that private people understand ??
#Biz_Security_Feb_2019
Did you apply the schedule you created on a new created policy route (the policy route to block your kid)?
If you want, you can even do web authentication on your device so that all your kids are under your control
https://support.zyxel.eu/hc/en-us/articles/360001378773-How-to-set-up-basic-web-authentication-on-a-hospitality-device
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
