Install TVHeadend on NAS326
Fusel
Is it possible to install TVHeadend on NAS326 and hardware strong enough to use?
On https://synocommunity.com/package/tvheadend a package for armada38x is aviable.
Can I use this for NAS326 by using MetaRepository and how do I use own packages in MetaRepository?
Sry for bad english - main german
#NAS_Feb_2019
#NAS_Feb_2019
To install it using MetaRepository it has to be repackaged as a ZyXEL package. Here you can find some documentation about how a ZyXEL package is made.But I remember a long thread on nas-central.org (which is down, unfortunately) which main conclusion was that getting the device drivers for the tuner working is a bigger problem than getting the binary running. And no, the Synology kernel modules won't fit on your 326.0
Thank you!
I will try to create/install the package.
Device driver should't be a problem, i plan to use an AVM DVB-C adapter.0
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
