How to RE-configure WRE6505 with a new home router ?
Menara
Hello
I have used WRE6505 for a while without any problems. But, now I have changed my home router and need to reconfigure WRE6505. The new router does not have the WPS button.
I have tried to reset it as described in the documentation without WPS and was hoping that would get me access to log in on zyxelsetup, but no luck. The repeater SSIDs request a confidential code which normally should be none
How do I log in again?
#Repeater_Mar_2019
#Repeater_Mar_2019
if you have the Ethernet port on your PC, try directly connect to your WRE6505 via Ethernet cable, and you should able to get the IP address from WRE6505 and able to login http://zyxelsetup/.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 482 News and Release
