Does multy u can connect to node with wire connection?
tonja
I have issue node disconnect from pk node.
I would like to connect pk node and node with wire connection for best performance.
#MultyU_Mar_2019
#MultyU_Mar_2019
ZYXEL official website has the information of Multy U. It supports Ethernet backhaul.
https://www.zyxel.com/products_services/AC2100-Tri-Band-WiFi-System-Multy-U/performance
App multy no choice to select (connect wire).
I will try to connect every node by wireless first and plug wire again
Thank you Hanamichi ^ ^0
- 234 Nebula Ideas
- 6.7K Security
- 707 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
