LG WK7 with Google Assistent work on guest nerwork, but NOT on my normal network
Woppy
Woppy Posts: 5  Freshman Member
edited March 2019 in Smart Home Product
I have a new LG WK7 ThinQ speaker, with Google assistant. I get the speaker in the guest network working, but not in my regular network, It is in the network but does not work. Please help me
#Router_Mar_2019
  • Mel
    Mel Posts: 83  Ally Member
    Which ZYXEL product you have the problem?
  • Woppy
    Armor Z1 ngb6816
  • Mel
    Can you share more information to clarify this problem? Such as screenshots, network topology, firmware version, steps ...
    So, LG WK7 ThinQ Speaker only works in Guest Network of NBG6816? When it connected to Main Network, what happened? And what do you mean it does not work? No respond or ... any detail explain.
  • Woppy
    the problem has been solved, I have received a firmware update from Zyxel and now everything is running properly, thank you
