LG WK7 with Google Assistent work on guest nerwork, but NOT on my normal network
Woppy
I have a new LG WK7 ThinQ speaker, with Google assistant. I get the speaker in the guest network working, but not in my regular network, It is in the network but does not work. Please help me
#Router_Mar_2019
#Router_Mar_2019
Which ZYXEL product you have the problem?0
Armor Z1 ngb68160
Can you share more information to clarify this problem? Such as screenshots, network topology, firmware version, steps ...
So, LG WK7 ThinQ Speaker only works in Guest Network of NBG6816? When it connected to Main Network, what happened? And what do you mean it does not work? No respond or ... any detail explain.0 -
the problem has been solved, I have received a firmware update from Zyxel and now everything is running properly, thank you
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
