Zyxel AP Configurator - File Transferring Failed
Dear community.
I am owning WAC6103D-I and today I am trying out Zxyel AP Configurator and set up the SNMP Get Community accordingly. My access point could be found using discovery.
However, when clicking on "Next" button I credential prompt and entered my admin credentials. But after that I am getting an error message "File transferring failed" and title "FTP Error" (without any further details). The credential prompt is not appearing anymore - that is why I guess that my given credential were correct. I also tried with starting AP Configurator as windows admin. I also enabled the firwall for AP configurator without any restrictions.
However, I have no idea what the issue might be. Any idea what I should check to get it working?
KR, Christoph
#Biz_WLAN_Mar_2019
KR, Christoph
#Biz_WLAN_Mar_2019
This might be caused by the FTP service on the WAC6103D-I was turned off.
If you can access the WEB GUI, please go to CONFIGURATION > System > FTP, and enable the FTP service.
If you only have the access of the SSH/console, you can use CLI command to show the status.
Router# show ip ftp server status
If "active" is no, please use the CLI command to enable it.Router# configure terminalRouter(config)# ip ftp server
Router(config)# write0
- 602 USG FLEX H Series
- 480 News and Release
