WAH7608 Installing the software via serial port
wpho
I have a LTE router Zyxel WAH7608.
A few days ago, my device suddenly went off and did not turn on when I tried to switch it on again. "Zyxel" appears on the screen, but does not open later. When I connect the device to the computer and hold down the reset button, it is connected to the serial port. I think there's a software problem on the device. How to update the software via serial port?
#LTE_Mar_2019
#LTE_Mar_2019
You can find it in user guide.
https://www.zyxel.com/support/download_landing/product/wah7608_22.shtml?c=gb&l=en&pid=20170301200003&tab=User_s_Guide&pname=WAH7608
It is the same problem for me and I tried to connect my Wah7608 on my computer but it doesn't work.0
Same problem. Guide is not helpful here.0
- 441 Beta Program
- 292 Service & License
