Are there any firmware updates for AMG 1312 TIIC since ABCG13 nearly a year ago?
untechie
untechie Posts: 3 image  Freshman Member
edited April 2019 in Smart Home Product
Does support for rotuers end after a certain period?
#SP_Apr_2019
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188 image  Zyxel Employee
    Sixth Anniversary
    Hi untechie,
    ABCG13 is latest fw for AMG1302-T11C. May I know if you have any issues with ABCG13 fw?
  • untechie
    No problems with the update thanks.  I had wondered if you stopped supplying updates after a few years as I had seen that the last update for AMG 1302-T10B,  a router I used to have,  was  over 2 years ago.
  • Afflospark
    Afflospark Posts: 5 image  Freshman Member
    As I hear you want to ask about new updates of AMG 1312 TllC.
    So I remind you that ZYXEL did not issue an update for yet. ABCG 13 Firmware is the latest update for AMG1302-T11C.
    Hope this will help you
  • untechie
    Thanks Afflospark for your advice.
