NWA1123-ACv2 Roaming configuration
Hi @Cyber
Roaming rule as below:
1.Create the same SSID name in two APs.
2.The SSID with the same security.
> Like AP-1 has SSID-1 with WPA2 security, the AP-2 must also set the SSID-1 with WPA2 security...or the device will disconnect the wifi.
3. The wifi coverage must overlap each other about -65dBm or lower.
> you can install inSSIDer in your PC or wifi scanner in your mobile phone and test the wireless signal in the middle location of two APs. Check two SSID's signal if lower than -65dBm. If you stand in the middle location and the device detect the signal is strong, then you need to downgrade the AP's output power.
4. The station connect the same SSID and get the IP must in the same subnet from two APs. Because roaming will not let station disconnect the wifi and it will not renew the IP or get IP again. To let the traffic smooth, the station's IP must can go through the AP to gateway after roaming.
this kind of configuration I have already. but this is not "roaming", as on roaming your client does not disconnect and reconnect, instead it roams.
Any other help? does this AP not support roaming?
Thanks!
BR
Alois0 -
Thanks. :-)0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
