vmg8823/8825 QoS Bandwidth
Biondo
Hi, both routers have the same issue. I want to use the bandwidth to limit the bufferbloat but, having a 200/20 connection, I cannot do it because the downstream seems to be stuck/limited at 130/140 Mbps, despite I set il on the GUI at 195 Mbps or even more. Am I expecting too much from the QoS?
#SP_Jun_2019
#SP_Jun_2019
Hi Biondo
Do you mean you want to manage the download bandwidth with QoS function, but the result seems the device output was limited around 130/140 Mbps only?
May I ask your FW version?0 -
Hi Hikari, sorry, but in the meantime I managed to lock the router after a FW flash; no password workin now!!
Which model? 8823 or 8825?0
Hi Biondo
What kind of password not working in your side? GUI login password or wireless password? If you still remember the FW version you tried please let me know.
And, if you are confusing the password, maybe long push the factory reset button on the shell, let device (password) recover back to the default setting. Then see if you can use the password again.0
- 588 USG FLEX H Series
- 477 News and Release
