Router Issue
Zaheer_Shaikh
Just Purchased NBG418n V2 router and observed that NAT is enabled by default, can anyone help how to disable it
#Home_Router_Jun_2019
How to disable NAT in NBG418Nv2 router
Just curious, why you wants to disable NAT feature on router mode?
You can change NBG418Nv2 as Access Point Mode, it will disable NAT feature.0 -
Hi thanks for the response, yes i want to disable it in router mode.0
Also i have taken lease line from TATA they have given WAN and LAN ip address pool for me to use. Since NAT is enabled by default is creating a problem for me.0
The release note mentioned that V1.00(AARP.9)C0 has added enable/disable option for NAT.
What is the firmware version of your NBG418Nv2?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
