[VMG8924-B10A] Router Zyxel733349
DGM
DGM Posts: 4 image  Freshman Member
edited June 2019 in Smart Home Product
Upgraded my broadband and sent  new router above.I'm used to solid lights on router when not active this unit has a permanently flashing globe since installation  2 weeks ago. ISP says that's normal are they right?
#SP_Jun_2019
  • Mihawk
    Mihawk Posts: 103 image  Ally Member
    Do you know its model name? It calls Zyxel733349?
  • DGM
    Zyxel 733349 is model number that comes up on my wifi
  • Mihawk
    Okay... But I couldn't find this model from the Internet... :/
    Can you share its firmware version?
  • DGM
    Thanks for comment I could not find the model listed either. I still have the box somewhere I'll look up the label. Appreciate your reply.
  • DGM
    The model on box shows VMG 8924 B10 A followed by C8544B733349. It could be firmware, going to check with ISP. Regards.
  • Αντετοκούνμπο
    Αντετοκούνμπο Posts: 1 image  Freshman Member
    @Zyxel_Support_CPE
    Can anyone help?
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188 image  Zyxel Employee
    Sixth Anniversary
    edited July 2019
    Hi DGM,
    May I know who is your service provider? If you would like to know firmware version, you can login to GUI and go to status page to check it.
    Below is LED behavior of VMG8924-B10A
