[VMG8924-B10A] Router Zyxel733349
DGM
Posts: 4 Freshman Member
Upgraded my broadband and sent new router above.I'm used to solid lights on router when not active this unit has a permanently flashing globe since installation 2 weeks ago. ISP says that's normal are they right?
#SP_Jun_2019
#SP_Jun_2019
Do you know its model name? It calls Zyxel733349?0
Zyxel 733349 is model number that comes up on my wifi0
Okay... But I couldn't find this model from the Internet...
Can you share its firmware version?0 -
Thanks for comment I could not find the model listed either. I still have the box somewhere I'll look up the label. Appreciate your reply.
The model on box shows VMG 8924 B10 A followed by C8544B733349. It could be firmware, going to check with ISP. Regards.1
Hi DGM,
May I know who is your service provider? If you would like to know firmware version, you can login to GUI and go to status page to check it.
Below is LED behavior of VMG8924-B10A
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 889 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 203 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
