How to connect HP Laser Jet Pro M132nw to Multy U
Energo
I was not able to connect the above device to Multy U. It has a WPS option and PIN. Both seems to useless with Multy U and currently I do not know what to do. Do not want LAN option of the device. Please help.
#MultyU_Aug_2019
#MultyU_Aug_2019
Multy U does not support WPS, so you need to manually setup printer's WiFi.
Here is the guideline of HP for your reference.
https://www.youtube.com/watch?v=t-kiWyiXjc4
https://support.hp.com/ca-en/document/c05216654
Sorry, but this does not help. If Multy U has a WPS button I would simply press it and choose WPS in menu of the printer. But Multy U does not support WPS and printer does not has deep wifi settings where I could choose the parameters. Even more - if I decide to choose LAN my comps also do not see the Laser Jet just because Multy U is a router and uses another IP range.0
WPS is a very big security risk, that is why Multy U does not have it. You have to connect your printer to a PC and then set up wifi from its setting
You can download "HP Easy Start Printer Setup Software" from the link.
https://support.hp.com/ca-en/drivers/selfservice/hp-laserjet-pro-mfp-m132-series/9365375/model/9365377
Following the guide line to set up your printer's wireless configuration.
https://support.hp.com/us-en/product/HP-LaserJet-Pro-MFP-M130-series/9365370/model/9365372/document/c05211196/
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
