Reset
Cristina
hi I pressed reset on my router the. Now my WiFi network is back to Zyxel NBG-418N v2 and is requiring a wpa2 password . What is that
#Home_Router_Aug_2019
I need it to log in0
If you have reset your NBG418Nv2, you can check its back lable, it will display default WiFi password. For the we interface of NBG418Nv2, default is admin/1234.
I think your NBG418Nv2 is customized product, you may need to contact your ISP provider to ask default WiFi password.0
- 441 Beta Program
- 294 Service & License
- 461 News and Release
