Reset
Cristina
Cristina Posts: 3 image  Freshman Member
edited August 2019 in Home Router
hi I pressed reset on my router the. Now my WiFi network is back to Zyxel NBG-418N v2 and is requiring a wpa2 password . What is that
#Home_Router_Aug_2019
  • Cristina
    I need it to log in
  • Hill
    Hill Posts: 156 image  Master Member
    edited August 2019
    If you have reset your NBG418Nv2, you can check its back lable, it will display default WiFi password. For the we interface of NBG418Nv2, default is admin/1234.
  • Cristina
  • Hill
    edited August 2019
    I think your NBG418Nv2 is customized product, you may need to contact your ISP provider to ask default WiFi password.
