gs1900-8hp can´t activate DHCP
hello Guys,
I try to activate DHCP in the settings of my GS1900-8HP
but after having chosen DHCP and pushing the button apply I cant access the system above the ip: 192.168.1.1
I need to restart the GS19... manually to get access again.
But the IPv4 is still static
can anybody help me?
Greetz philipp
#Biz_Aug_2019
Greetz philipp
#Biz_Aug_2019
Because you change GS1900's ip to DHCP and it should get the new ip address from DHCP server then you will not be able to login via 192.168.1.1 ip address.
Since switch was not saved the configuration that is why you can use 192.168.1.1 to access after GS1900 rebooted.
I suggest that you can download the ZON Utility to modify GS1900 ip and it also can detect the new ip address.
Here is the download link page:
https://www.zyxel.com/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
Enjoy it!
Ace0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 491 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
