Connect a telephone to LTE 3302-M432
Biddulph
Biddulph Posts: 1 image  Freshman Member
edited January 2024 in Mobile Broadband
I have a LTE3302-M432 and would like to connect a telephone to it.  I got lost in confusion about so many options when looking at voip phone websites.  Alternatively, is there a cheap conversion unit from conventional landline phones to voip via your router?
#SP_Sep_2019
  • bbb
    bbb Posts: 35
    Sixth Anniversary
    edited September 2019
    Hi Biddulph,
    The LTE3302 does not have an RJ-11 port, it does not provide VoIP services; and it does not have a converter either. If you are looking for VoIP services, maybe you consider the Zyxel VMG series.
    Regards,
    Bob
