AMG1302-T11C Won't Portforward
MrCooksterOne
Trying to create a minecraft server for me and the boys, no matter what port I try to portforward, they can't connect to the server and canyouseeme.org says it can't find my service because the connection times out. Is this a router thing or an isp thing?
#SP_Sep_2019
#SP_Sep_2019
Hi MrCookserOne
May I ask if you build up the server in CPE LAN side (192.168.1.X)? how do you want to access? I mean you and your family device are also in LAN side or somewhere in WAN side (Public IP). How do you want traffic forward? Let's discuss the topology first!1 -
I'm not sure what CPE LAN side means or what it is for, but I know i want to make it public for friends that are in different countries than me. And is there more than one way to forward traffic?
Hi MrCookserOnePlease try to configure Forwarding in your device.1. Login AMG GUI, go to NAT > Port forwarding, Add new rule
2. Do you buildup the server like this page introduced? https://www.purevpn.com/port-forwarding/minecraftI assume you and your friends are PC player, so I use "PORTS TO FORWARD ON PC" TCP: 25565. If your friend access (AMG WAN IP: 25565), AMG will help to forward the traffic to LAN side Minecraft server.Note: LAN means your home network.
- 588 USG FLEX H Series
- 477 News and Release
