IPV6 on Multy X
phoner123
phoner123 Posts: 9 image  Freshman Member
Is IPv6 turned on as standard on a Multy X? If not is there a way of switching it on? I am trying to add a NEST protect to my home and NEST customer services have advised that I am struggling to do so because IPv6 may not be tunred on or compataible with the Multy devices
Many thanks
  • Zyxel_Eric
    Zyxel_Eric Posts: 279
    First Answer First Comment
    image  Zyxel Employee
    Hi @phoner123,
    iPv6 is on by default of Multy. You can check the status of iPv6 on the detail page of Multy.
    Please make sure that your ISP has provided the iPv6 to your network.
  • odifoke
    odifoke Posts: 29
    I also have Nest thermostat and fire alarms and they all worked automatically with IPv6.
