How to set up vmg router with Engenius enh500 as a Access Point
Bear33
I received a Engenius enh500 as a gift and I'm not sure how to get it connected to a vmg router. I would like to know what settings I need to change on the router to make it work. I guess I'm just not computer savvy enough to get it done. THANKS
#SP_Oct_2019
#SP_Oct_2019
Hello @Bear33There is a manual for the ENH500 at https://www.engeniustech.com/resources/ENH500%20User%20Manual%20v.1.0.pdfIf you wanted to use the ENH300 as an outdoor access point, then it could be connected to one of the LAN Ethernet ports of a VMG router, but it might need some expertise to do it.I hope that this is helpful.Merry Christmas and Happy New Year.Tony0
- 588 USG FLEX H Series
- 477 News and Release
